Activity Forums Apple Final Cut Pro Legacy ‘general error’ and ‘out of memory’ messages…
  • ‘general error’ and ‘out of memory’ messages…
    Posted by Adam Heayberd on February 22, 2011 at 3:44 pm
    I was working with a project in motion, which when exported to FCP and into the sequnece caused the ‘general error’ and ‘out of memory’ error signs.
    I cant be out of memory, its a brand new mac tower with added RAM and a 4TB G-Speed es added to it as the scratch disc.
    When I put in the original clips before the motion project, when prompted I changed the sequence settings to match the clip settings.
    Should I have done that? Im not quite sure what the ideal Sequence settings should be and this is pretty demoralising given the workload I have 🙁
    Anyone any suggestions?
    Adam
    Editor & Self Shooter in the UK
    Paul Jay replied 15 years, 6 months ago 4 Members · 5 Replies
  • Michael Gissing
    February 22, 2011 at 9:06 pm
    There are lots of reasons behind the “out of memory” error message and a search of this forum will explain many of them. There have also been lots of posts about problems and instability in using Motion templates and round tripping.
  • John Doggett-williams
    February 22, 2011 at 11:32 pm
    Yes this subject has been tackled many times on these forums – the culprit in my case is usually oversize stills
    John doggett-williams
  • Paul Jay
    February 23, 2011 at 9:05 am
    Did you save the Motion project and imported it in FCP?
    or
    Did you export a quicktime movie from Motion?
    or
    Did you send a clip from FCP to Motion and then hit save?
  • Adam Heayberd
    February 23, 2011 at 9:30 am
    I did both the first 2 options.
  • Paul Jay
    February 23, 2011 at 11:11 am
    With the first option you always will have to render that in FCP.
    Motion 3 always exports a quicktime Animation file , if you don’t change export settings
    Motion 4 always exports a ProRes 4444 file , if you don’t change the export settings.
    What are your current Sequence settings in FCP?
    What are the properties (size, codec ) of your created Quicktime movie from Motion.
