Activity Forums Apple Final Cut Pro Legacy general error (41) Can’t open any projects
  • general error (41) Can’t open any projects
    Posted by Hollie Osborn on May 4, 2010 at 11:35 am
    I’m panicking slightly as I have just returned from Thailand having been away from my computer and hard drive for 5 months. I have tried to open up any off my projects in final cut pro and it won’t open any of them – it just says general error (41). Can you think what this might be? something in the settings? Surely the files can’t be corrupted as they havn’t been used?
    Many Thanks
    Hollie Osborn
    Hollie Osborn replied 16 years, 4 months ago 2 Members · 2 Replies
  • Richard Cooper
    May 4, 2010 at 7:44 pm
    Hi, I found this on the Apple discussion forums…
    “Since 41 is a Finder error, you might try removing ‘com.apple.Finder.plist’ from the Computer-> Users->your name->Library->Preferences folder. If you don’t feel comfortable trashing it, just move it to the desktop. Do a restart, and a new file will automatically be created.
    Or, before doing that, try another Software Update. It could be you stopped doing the Update too soon, since some files have be installed in a set order. So even after installing a long list of updates, Software Update needs to be selected again to check for updates to the updates just installed.”
    This solved the problem for this particular user.
    Hope this helps.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Hollie Osborn
    May 5, 2010 at 1:54 pm
    Thanks for the idea but unfortunalty it didn’t work, it still comes up with general error (41) when i try and open any HD material. Do you think the problem is with my external or with final cut? and can you think of any other solutions to this?
    Many Thanks
    Hollie Osborn
