Activity › Forums › Apple Final Cut Pro Legacy › General Error
General Error
Posted by Richard Rodriguez on August 7, 2009 at 5:15 pmHello all,
I keep getting a General Error during a Quicktime export. I have tried the export self-contained and not self-contained. The sequence setting are XDCAM 1080I60, Square, Upper.
I need to get it out of FCP to convert to Flash and DVD.
Any possible help would be great appreciated.
Thank you in advance,
Richard Rodriguez
Digital EdgeJohn Fishbackreplied 17 years, 1 month ago 3 Members · 4 Replies
John Fishback
August 7, 2009 at 6:13 pmIt could be a bad render. You can try deleting the renders with Render Manager and re-render. Then see if you can export. If that doesn’t work, it’s possible you’ve got corrupt media. To narrow down where in the sequence the problem may be, try exporting smaller segments. If one doesn’t work, then look to that segment as having bad media.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jesse Watson
August 17, 2009 at 4:09 pmJust ran into this myself. For me, the problem ended up being the external hard drive I was using (both the source files and destination directory were on it). Moving both the source and destination to my local HD fixed it for me. Not to say that there might not be many other causes of “General Error” (nice error message).
Richard Rodriguez
August 17, 2009 at 4:22 pmThank you.
I will make sure to separate in the future.
Richard Rodriguez
John Fishback
August 17, 2009 at 5:43 pmMake sure you never use your system drive as your scratch drive. Another possible reason for the error might be corrupt drive directories. Run Disk Warrior on your system and external disks. IMHO, Disk Warrior is the most important utility to have if you use a Mac.
John
