Activity Forums Adobe After Effects General 3DS Max to AE workflow questions…
  • General 3DS Max to AE workflow questions…
    Posted by Rich Seemueller on April 25, 2008 at 11:48 am
    Hey all,
    I am beginning to dabble in and learn 3D Studio Max. I’m wanting to incorporate 3D elements into my designs, but am unsure of the best workflow. Is there a good site or thread that anyone knows of dealing with these questions?
    One big questions is that if I do an animation in 3DS Max and want to composite it in AE, do I have to manually match the AE camera, or can I export 3DS Max camera data and use that to match the camera moves.
    I’m a newbie on this stuff so any help would be MUCH appreciated. Thanks!
    Rich Seemueller
    Jeff Dobrow replied 18 years, 5 months ago 2 Members · 1 Reply
  • Jeff Dobrow
    April 25, 2008 at 12:09 pm
    You can use the RPF file format to render, and then use that info to create a camera in AE. BUT, you will find that it is very, very limited.
    There is more to it than ‘matching the camera’. You need to be able to sync AE elements (layers) within your 3D space so everything seems like it’s in one environment.
    The “only” way to be able to handle all this properly is with the plugin MAX2AE (boomerlabs.com). This allows for seamlessly transferring all your camera, object and light data from MAX into AE, AND allowing you to transfer from AE into MAX as well.
    So you can go back and forth, tweaking camera and objects/layers in either application!
    It is a night and day difference from any other workflow available.
