Activity › Forums › Audio › Genelec XLR daisy chaining
  • Genelec XLR daisy chaining
    Posted by Philip Fass on December 5, 2008 at 2:00 pm
    When you daisy chain two Genelec speakers through XLR, do both of them give you mono, or do they somehow separate the L/R channels?
    Philip Fass replied 17 years, 10 months ago 2 Members · 2 Replies
  • John Fishback
    December 5, 2008 at 9:31 pm
    That set up would most likely give you a mono feed to both. The XLR is designed primarily for a balanced feed, not left and right as with some consumer audio. You’d feed each Genelec with a cable from your mixer – one for each channel, however many channels you have.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Philip Fass
    December 6, 2008 at 12:10 pm
    I’m surprised they would market the daisy-chain feature. I can’t imagine many situations where you’d want the same audio coming out of each speaker. Unless in a multi-room setup, you’d connect all the L and all the R speakers with the XLRs.
