Activity › Forums › Panasonic Cameras › Gel Power for DVX100
  • Gel Power for DVX100
    Posted by Michael Brown on April 17, 2006 at 7:47 pm
    I’m thinking about using a 12v gel-type battery for our DVX100. However, I know from the manual that it takes 7.9 volts. Are there any handy converters I can use to step this down?
    Mike Brown
    Video/Film Producer
    American Heart Association
    Michael Brown replied 20 years, 5 months ago 5 Members · 6 Replies
  • Julie Meek
    April 18, 2006 at 2:00 pm
    Hmm, you might be happier using a small 110v inverter plugged into the Gell, then use the 110 power attachment for the DVX. Then everyting is off the shelf hook up.
  • Tim Scarpino
    April 18, 2006 at 8:42 pm
    Do you really wanna risk your camera in this way? What’s the point?
    I’m genuinely curious.
    Tim
  • Michael Brown
    April 19, 2006 at 11:53 am
    The point is very long running times (all day) without AC power. The battery would power a small LCD monitor as well.
    Stepping down the 12v would require building a voltage regulator, and that may not be worth the benefit. Such things are available for Sony, Canon, but not for the DVX100 however.
    Mike Brown
    Video/Film Producer
  • Bpetefla
    April 19, 2006 at 4:45 pm
    Think about the Gel to inverter to the DVX 110 adapter. I have it, I’ve done it and it works. I have a Dryfit Gell battery (About the size of a motorcycle or riding mower battery or slightly bigger),that I used to run my Arriflex all day long on location. So I took it along when shooting DVX outdoor interviews for the best part of the day. It stays on the cart and gets rolled around. Also I run a small sony monitor to check setup etc., off the inverter. My 2cents worth.
    Bpete
  • Barry Green
    April 20, 2006 at 12:42 am
    [Michael D. Brown] “Such things are available for Sony, Canon, but not for the DVX100 however.”
    Would this help?https://www.dolgin.net/DCConverterPan.htm
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Michael Brown
    April 20, 2006 at 12:30 pm
    Well, there you go! The COW scores again! Thanks Barry!
    Mike Brown
    Video/Film Producer
