Activity › Forums › Adobe Premiere Pro › GeForce GTX 1060 with 3 gigs memory
  • GeForce GTX 1060 with 3 gigs memory
    Posted by Eric Merklein on March 23, 2017 at 2:21 pm
    I think I found a desk top that I like, but still confused about graphics card specs. The Nvidid GeForce GTX 1060 looks like a good bet, but it’s not in the official list from Adobe.
    Any advice would be much appreciated.
    Eric
    Many thanks.
    Jeff Pulera replied 9 years, 6 months ago 2 Members · 1 Reply
  • Jeff Pulera
    March 23, 2017 at 3:25 pm
    Hi Eric,
    Adobe does not test or list all compatible cards. Basically, anything newer with minimum 1GB memory should work. The GTX 1060, most definitely! If you will be working with 4K, then maybe look at the GTX 1070 as an upgrade. Tests I’ve seen show little difference in render times for 1070 vs. 1080, so 1070 is best I would go unless you have money to burn, but nothing wrong with 1060.
    Jeff Pulera
    Safe Harbor Computers
