Activity Forums Adobe Premiere Pro GeForce GTS 250 not enabling cuda acceleration in premiere pro
  • GeForce GTS 250 not enabling cuda acceleration in premiere pro
    Posted by Cherlique Lilienthal on January 22, 2013 at 4:34 am
    hey guys,
    today I upgraded from my GeForce 9400 GT (1GB) to a GeForce GTS 250 (512MB) I first unlocked the cuda features for after effects using the command prompt, GPUSniffer and adding the card to the list. then I proceeded to unlock for adobe premiere pro, only this time the gpu acceleration option doesn’t show up in the render engine settings in premiere pro. why wouldn’t this work? the first time I unlocked the GeForce 9400 gt without a problem. so what could be the issue?
    Kevin Monahan replied 13 years, 8 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    January 22, 2013 at 5:22 am
    Your card doesn’t have enough memory.
  • Cherlique Lilienthal
    January 22, 2013 at 5:56 am
    so how much memory would I need? I thought memory was only significant when using large monitors.
  • Tero Ahlfors
    January 22, 2013 at 8:52 am
    The accelerated Mercury Playback Engine requires at least 896 MB from the GPU.
  • Kevin Monahan
    January 22, 2013 at 9:58 pm
    I don’t recommend a video card that is not certified by Adobe. That said, please don’t try and enable a non-supported card that has less than the required VRAM. You’ll experience more headaches than they’re worth. If you would like a video card supported for the Mercury Playback Engine, make a feature request: https://www.adobe.com/go/wish
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
