GearShift question for John Rofrano
I’ve used gearshift on my windows 7 32 bit machine for several projects (editing M2t clips)in vegas pro 10 . I just built a new windows 7 64 bit machine & when I try to install gearshift it says “vasst gearshift requires vegas pro , a compatible vegas pro install could not be found”. I’m using vegas pro 10 64 bit . If I can’t use gearshift , how would you recommend editing m2t projects?
