Activity Forums Apple Motion Gaussian Blur/Bounding Box Problem
  • Gaussian Blur/Bounding Box Problem
    Posted by Kai Whittaker on October 23, 2007 at 2:20 pm
    I have a problem with a photoshop layer I imported into one of my Motion projects. It’s basically a silhouette/profile of a gear wheel. i added a spin to it so that it rotates slowly. I’d like to add a second, blurred out gear., When I add a gaussian blur to the gear, it cuts off at the edges where the bouncing box is. In after effects I’d use repeat edge pixels or something like that. Is there an equivalent in Motion?
    Kai
    Arnie Schlissel replied 18 years, 10 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    October 23, 2007 at 8:32 pm
    Put the image you want to blur in it’s own layer. Apply the blur to that layer, not the object. Select the Layer tab in the inspector & check the box to make the layer “Fixed Resolution” with the resolution equal to that of your comp settings. The blur should now spread out past the edges of the gear’s bounding box.
    You’ll find that many effects work better on layers than the objects inside them. Or that you can apply an effect, mask or transform to several objects at once by dropping them into a single layer. Once you get the hang of it, you’ll find that it can be a powerful option- when it’s not annoying!
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
