Activity › Forums › Maxon Cinema 4D › Garbled objects on R17
  • Garbled objects on R17
    Posted by David Cabestany on May 18, 2016 at 3:09 pm
    Hello all,
    It happened twice already on a large complex model I’m animating that by doing seemingly harmless things will corrupt the polygons on the model, effectively ruining several hours of work.
    The first time I have no idea what caused it, I suspect a pose morph tag, but it didn’t even show on the editor, I only realized it when I rendered the view port and by then it was too late to undo.
    The second time, I selected several polygons and converted them into a an xRef, I opened the new document created document and when I returned to the main file everything related to that new xRef looked garbled. I was able to undo and redid the xREf; this time it worked ok. Then I added a cube just for the sake of testing if it was refreshing accordingly and everything worked ok until I deleted the cube from the scene, where everything got garbled and changed position once I reloaded.
    It looks more like a bug than a byproduct of a wrong workflow to me. Anyone else experiencing this?
    I’m using R17 freshly purchased by my friend 2 days ago, all the updates installed, running on a MacPro with 64gb ram and two AMD FirePro D700 graphics cards.
    Thanks.
    D.
    Brian Jones replied 10 years, 4 months ago 2 Members · 2 Replies
  • David Cabestany
    May 19, 2016 at 2:29 pm
    No one?
  • Brian Jones
    May 19, 2016 at 2:30 pm
    never have seen it or even heard of it before. Try contacting Support
