Activity › Forums › Apple Final Cut Pro Legacy › Garbage matte tags
  • Garbage matte tags
    Posted by James Hargreaves on December 8, 2005 at 1:36 pm
    I am using a four point garbage matte and after it is rendered I am getting odd frames where at least two of the matte’s point tags (number labels) flash up.
    I reset from scratch and it still does it.
    Any help on this would be appreciated.
    James Hargreaves replied 20 years, 10 months ago 2 Members · 2 Replies
  • Debe
    December 8, 2005 at 3:04 pm
    Did you try turning off the tags before you rendered?
    Switch the drop down in the filters tab to “Final”. It’s likely set to “Preview”.
    Try that. Post back if it doesn’t help!
    debe
  • James Hargreaves
    December 8, 2005 at 5:49 pm
    Yep – that’s the one.
    Thanks :o)
