Activity Forums Apple Final Cut Pro Legacy Garbage matte layer postion in effects stack
  • Garbage matte layer postion in effects stack
    Posted by Anthony Faulkner on May 9, 2012 at 1:13 am
    Does it matter in terms of computing power and render times where the garbage matte is placed in a series of effects applied to a composite clip?
    Is it better to leave it off where possible?
    Rafael Amador replied 14 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 9, 2012 at 1:44 am
    Don’t think it would matter when in the list it’s added.
    The second question I don’t quite understand, other than the fewer the filters the faster the render probably.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Rafael Amador
    May 9, 2012 at 9:23 am
    [anthony Faulkner] “Does it matter in terms of computing power and render times where the garbage matte is placed in a series of effects applied to a composite clip?”
    In theory, applying the Garbage matte first should reduce the rendering time cause the other effects will be applied to only part of the picture (the matted one).
    Not sure if in real life this happens.
    rafael
    http://www.nagavideo.com
