Activity › Forums › Apple Final Cut Pro › Gaps inserted when cutting and pasting
  • Gaps inserted when cutting and pasting
    Posted by Jeff Raskin on December 14, 2017 at 11:00 am
    I am a noob to FCPX, but not to the business. In fact, I started when editing meant flatbeds and splicing blocks, progressed through low and high-end linear video editing, and started with NLEs in 1990 with Montage (anybody remember those 17 betamax decks?).
    I am helping a friend finish a project, inheriting their timeline and MacBook Pro (Retina 13-inch, Early 2015) that it was assembled with (using FCPX 10.3.4). The timeline is over 2.5 hours long, and has nine audio tracks synched, as well as a couple of music tracks (OK, I know you call them lanes in FCPX…). I am tackling audio first, and there are performance issues redrawing all those waveforms, so I chopped the timeline up into five roughly 30 minute chunks.
    My problem is that as I am reassembling the timeline (Command A to grab everything, Command C to copy everything, and then Command V to paste each segment back to back), lots of 1 frame gaps are being introduced into the copied and pasted video lane, and some audio is slipping out of synch. I must be doing something wrong. Anyone seen this and solved it? Any insight would be appreciated.
    Jeremy Garchow replied 8 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    December 15, 2017 at 12:18 am
    Do all of the frame rates match on all of the projects?
    This happens when you copy and paste disparate frame rates in to each other (like copying footage from a 23.98project in to a 25 timeline, and the footage is 29.97 or something silly).
