Activity Forums Adobe After Effects gaps in a complex mask – how to join vertices
  • gaps in a complex mask – how to join vertices
    Posted by Chris Brooke on February 1, 2012 at 6:00 pm
    I have just been creating a complex bezier mask with the pen tool. When I got to the end I found I couldn’t close the path. It turns out the are a couple of gaps in the path (I must have Cmd-clicked by mistake). Is there a way to close these gaps? Either by merging/combining vertices?
    The mask took me ages to do an I don’t want to have to start again.
    Roland R. kahlenberg replied 14 years, 6 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    February 1, 2012 at 9:56 pm
    I never knew that you could have multiple gaps within a single mask path – are you certain that you have only one mask?
    BTW, to close just a single part
    1) with the selection tool, select the last vertex you drew
    2) switch to the pen tool and click on the first vertex you drew
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Chris Brooke
    February 2, 2012 at 1:53 pm
    Hi there,
    Sorry, I didn’t explain myself very well. The gaps caused the creation of three separate masks which I need to just be one mask.
    I found a work around by copying the paths into Illustration and using the Join Vertices function to close the gaps by highlighting the two points I wanted to join. I then copied the path back in to AE.
    I find it a bit odd the AE doesn’t seem to have this function. Hey-ho.
  • Tylor Larson
    February 2, 2012 at 8:43 pm
    using illustrator as a stepping stone is the best method i have found as well… the AE path tool is missing some key features. Lets hope adobe looks at these forums.
    February 3, 2012 at 12:35 am
    Good solution Chris and thanks for sharing!
    Cheers
    RoRK
