Activity Forums Apple Final Cut Pro Legacy Ganging and setting In on-the-fly
  • Ganging and setting In on-the-fly
    Posted by Al Sinclair on May 29, 2007 at 8:11 am
    Morning.
    Here’s something that’s been bugging me – can’t figure out if I’m missing a setting or if it’s just the way things are:
    I’ve got my Canvas and Viewer ganged, with the Viewer active… If I play, then set an “in” on the fly, the playhead jumps back to its original position! The in-point is set where I want, but why on earth does the viewer jump back rather than continuing to play?!?
    I’ve just upgraded to FCS2, but this was happening in the last version too… and on all our machines.
    Like I say, I’m sure I’ve just missed something somewhere along the line.
    Hopefully.
    Thanks in advance,
    Al
    Al Sinclair replied 19 years, 3 months ago 3 Members · 4 Replies
  • Will Macneil
    May 29, 2007 at 3:28 pm
    You’re not using the ‘open’ mode are you?
    W
  • Al Sinclair
    May 30, 2007 at 12:07 pm
    Nope – just a straight Gang.
    Is no one else seeing this behaviour?
    Here’s a step-by-step:
    Sequence in the canvas
    Clip in the viewer
    Select Gang from Viewer drop-down
    Hit Play in the Viewer
    Tap “i” to set an In Point
    …and that’s where it jumps back to the original playhead position!
    Any light to be shed on this???
    Thanks again,
    Al
  • Tom Wolsky
    May 30, 2007 at 12:18 pm
    Yes, that’s what happens. Not sure why that’s the behavior. May be a back and not by design. If you reverse it, play back the timeline or canvas and mark an In point, playback stops.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Al Sinclair
    May 30, 2007 at 12:34 pm
    Yeah – I’ve never really liked the way it does that either!
    Doesn’t look like this can be changed, does it…?
    Never mind, eh.
