Activity › Forums › Apple Final Cut Pro Legacy › Gang Sync Multiclip to a sequence
  • Gang Sync Multiclip to a sequence
    Posted by Steve Chrome on August 2, 2006 at 3:45 pm
    Hi There,
    I’m cutting music video which was previously being cut on FCP4.5 and i’m now using FCP5 [although i’m new to FCP5], already there is part of an edit within a sequence, which i am tidying up and adding shots to.
    So i’ve created a multiclip out of all the performance shots,and i’m thinking that i want to be able to gang sync the multiclip to the already editited sequence, but i’ve found that if i select a shot in the multiclip the gang sync is lost, this isn’t a major problem, but slightly tedious, am i missing something ?
    also i can’t seem to just set an in and out point in the multiclip and drag the shots onto the timeline… am i just going about this the wrong way ? or is this just not possible with the multiclip function ?
    Any advice would be much appreciated
    Cheers
    Eddie
    Steve Chrome replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
