Activity Forums Adobe After Effects Gamma shift when importing Prores in Adobe After Effects 6.0
  • Gamma shift when importing Prores in Adobe After Effects 6.0
    Posted by Polona Kuzman on December 22, 2012 at 11:19 am
    I was searching on the net about this one, but can only find old issues wait gamma and prores in old versions of AE, so I hope someone can give me a hint about this one.
    I am trying to import Prores HQ file (that was color corrected in Rec709) and export it to a j2c sequence in DCDM X’Y’Z (gamma 2.6) 5900K by using Fnord plugin for j2c sequence.
    The results are too bright and the colors wached out.
    I am comparing to the results to what I get with EasyDCP creator and to the results I get with OpenDCP conversion of tiffs that I exported from Quicktime 7.
    • I am using After Effects 6.0 (11.0.0.378) on Osx 10.7.5.
    • The file I am trying to import is probably made with Final cut pro.
    • In the interpret footage settings the Prores HQ file has an embedded profile: HDTV (Rec. 709) Y’CbCr and I cannot change that (it’s grayed out). I am puzzled about this, because when I am exporting from AE to Prores HQ it says this format cannot have embedded profile.
    I hope someone knows what might be the problem.
    P
    Polona Kuzman replied 13 years, 8 months ago 2 Members · 3 Replies
  • Terrence Meiczinger
    December 22, 2012 at 10:25 pm
    How are you viewing the results?
  • Polona Kuzman
    December 23, 2012 at 12:37 pm
    Measuring color values with Digital Color Meter in Photoshop and Easy DCP player.
  • Polona Kuzman
    January 3, 2013 at 4:15 pm
    I was able to check my test reels in a cinema today.
    The DCP converted with Adobe looks washed out. After applying gamma adjustment (Color Finesse Gamma 0.8) it gets a bit closer to what it should be …
    Where am I going wrong?
