Activity Forums Blackmagic Design Gamma shift problem with tiff-sequence
  • Gamma shift problem with tiff-sequence
    Posted by Bill Nelson on November 13, 2008 at 6:12 pm
    Hi everyone,
    I got a tiff-sequence which I loaded into Apple Color. I chosed the Blackmagic 10 Bit Codec for render to generate a Quicktime. I got the same clip also on Digibeta which I loaded into Final Cut. When I compare my tiff-to-quicktime clip from color and the clip from the digibeta, I get this well known gamma shift.
    I know that this problem occurs because the tiff-files a RGB and Color treats them with 1,8 gamma. (when I put a single tiff-file into final cut and set the gamma manually to 2,2 the frame is correct).
    BTW – the gamma shift is not only on the monitor but also on my waveform monitor via blackmagic decklink extreme-SDI.
    I really need a way to generate clips from tiff-sequences with the correct gamma.
    Any help for me?
    Thank you!
    Margus Voll replied 17 years, 10 months ago 2 Members · 1 Reply
  • Margus Voll
    November 15, 2008 at 11:35 pm
    Hi.
    Open tiff’s in Quiqtime Pro as one video file. Save it as mov. Use compressor to export is in a format you like and in export settings say that you have gamma 2.2. This is not a fine tuned work flow description but generally it should do it.
    Play around with compressor.
    Margus
    https://iconstudios.eu
