Activity Forums DaVinci Resolve Gamma Shift in FCP7 Roundtrip?
  • Gamma Shift in FCP7 Roundtrip?
    Posted by Dimitrios Papagiannis on September 20, 2011 at 1:59 am
    HI all
    I did a roundtrip from an fcp7 timeline/xml to Resolve
    Did a basic color correction
    Rendered out the (Roundtrip tp FCP 7)
    Exported an xml from the conform window
    Opened a new project in FCP
    Imported the project(resolve).xml into FCP
    Looked at the shots in the fcp timeline and they were much darker.
    Am I doing something wrong?
    Marc Fisher replied 15 years ago 6 Members · 5 Replies
  • Chad Terpstra
    September 20, 2011 at 2:30 am
    Make sure you don’t have filters still applied in FCP7. I’m still new to Resolve but from Color sometimes the filters would stay on after the roundtrip process.
  • Margus Voll
    September 20, 2011 at 4:36 am
    fcp ui also shows off colors some times. look at external monitor.
    what compression do you use ?
    Margus
    https://iconstudios.eu
  • Vladimir Kucherov
    September 20, 2011 at 12:51 pm
    I think it’s actually stated somewhere that the software preview window of FCP 7 shows video with a different gamma.
    Render out the file from FCP and compare the two in quicktime side by side, or preview from FCP on a broadcast monitor. Still gamma shift?
  • Hans Petter birkeland
    September 20, 2011 at 8:11 pm
    Perhaps you rendered RGB in stead of YUV by accident? I have done that myself, and the output is wrong.
    Hans Petter Birkeland
    colorist
    NRK, Norway
    https://flickr.com/photos/hpb/
  • Marc Fisher
    September 23, 2011 at 7:10 pm
    Also, check out your Quicktime PLayer preferences. there’s a check box for Gamma setting to match FCp 7 or legacy or something like that.
    s well, when you create a quicktime, i know in the compression settings tab, is a drop down button fro Auto or none for Gamma adjust. I’d follow this path a bit to see where it leads..
