Activity Forums Media 100 Gamma shift as Boris titles come in
  • Gamma shift as Boris titles come in
    Posted by Andy Taplin on July 11, 2011 at 11:04 am
    Hi All
    Just had a strange issue where the gamma of the BG video goes higher as a Boris title comes in from the V1 track – and then back to normal after the fade out. You don’t see it in Media 100 but only once exported to QT as either by-ref or self-contained. I’m working in the Media 100i codec for this project with 13.0.4 and OSX 10.5.8, QT 7.6.9. No time to try and resolve the problem so I did the title in AFX.
    I’ll do some tests this week but in the meantime does anyone know what’s going on here?
    Andy Taplin
    Director / Lighting Cameraman
    https://www.andytaplin.co.uk
    Andy Taplin replied 15 years, 1 month ago 2 Members · 6 Replies
  • Floh Peters
    July 11, 2011 at 11:10 am
    That´s the joy of QuickTime. Media 100 i codec uses a different RGB colorspace than Apple codecs. So if you render something in ProRes, it looks different, at least in QuickTime player. The solution is to do a QuickTime export into the codec of your choice (not as by ref or self contained), or to stay within a single codec on your timeline.
  • Andy Taplin
    July 11, 2011 at 11:17 am
    Thanks for the quick response Floh. I have not changed the codec on the timeline – it’s M100i throughout so the rendering of titles is also M100i so there shouldn’t be any gamma shift when rendering the titles should there?
    I did a project using M100i about a month ago and did not have this problem then – nothing’s changed.
    Andy Taplin
  • Floh Peters
    July 11, 2011 at 11:20 am
    yeah, I bet it render in something different. Locate the rendered file in your Rendered Media directory, and open it in QuickTime Player. Command-I to get the clips infos, and there you should see the used codec.
    Make sure your render settings are correct, and try to rerender.
  • Andy Taplin
    July 11, 2011 at 11:31 am
    Just looked at the rendered media file in QT player and it’s definitely Media 100i – the only thing I can think of is I rendered it lossless – not that that should make a difference?
    Andy Taplin
  • Floh Peters
    July 11, 2011 at 11:43 am
    [Andy Taplin] “not that that should make a difference?”
    No.
    Just get over it and export via QuickTime.
  • Andy Taplin
    July 11, 2011 at 11:52 am
    OK, that works, thanks Floh.
    Andy Taplin
