Activity › Forums › Apple Final Cut Pro Legacy › Gamma Shift After Rendering 8 Bit Uncompressed Footage
  • Gamma Shift After Rendering 8 Bit Uncompressed Footage
    Posted by Captmorgan on March 1, 2006 at 5:44 pm
    I’m getting a really bad black level shift after I render in Final Cut 5. I’m using the final cut 8 bit uncompressed codec, which is what the footage was captured at. Before I render, the preview quality looks fine, but once I render it out, it looks awful, the blacks get a lot brighter, to the point where there’s no detail at all. I’ve changed all my video output settings in the render settings to all the settings possible, and nothing works. I use an AJA iola for video output/capture, but I know it’s not that becuase I hooked my sysem up through a normal firewire setup and it does the same thing. It seems to do it everytime I render, and it doesn’t matter what kind of fiter or change I’m making to the video. Any help would be greatly appreciated. Thanks.
    2gig dual core G5, OS X 10.4.5, Final Cut Pro 5, AJA iola
    Captmorgan replied 20 years, 7 months ago 3 Members · 3 Replies
  • Chris Poisson
    March 1, 2006 at 7:45 pm
    This is not normal. Suggest you trash your prefs, repair permissions and restart.
    Have a wonderful day.
  • Doug Bassett
    March 1, 2006 at 7:54 pm
    I had this with the Black Magic codec but an update of the drivers fixed it. Not sure about the AJA stuff, maybe see if you have the latest.
  • Captmorgan
    March 1, 2006 at 7:56 pm
    got the latest AJA drivers as well. like I said, it does it when I hook a firewire DVCAM deck and output through that.
