Activity Forums DaVinci Resolve Gamma-Shift
  • Sascha Haber
    July 20, 2015 at 4:09 pm
    Classic scaling error.
    You are rendering video to data accidentally.
    Change your project setting, viewing settings, interpret footage correctly. Done.
    Resolve 11.3 – Smoke 2015 EXT1 – Sapphire 8
    Colorist / VFX Guru / Aerial footage nerd
    https://vimeo.com/saschahaber
    https://dk.linkedin.com/in/saschahaber
  • Marc Wielage
    July 21, 2015 at 2:46 am
    The differences will be more apparent (and measurable) if you use SMPTE bars and/or a full-screen grayscale and check the scopes. This will give you the clues towards the workflow you need to follow.
  • Eric Sternberger
    July 21, 2015 at 11:37 am
    Thanks, Sascha!
    In the Rendering Tab “Video/Data Level” was set to Auto.
    Setting it to “Video” solved this…
