Activity Forums Apple Final Cut Pro Legacy Gamma problem – ProRes 422 vs. LT / Proxy / JPEG
  • Jeremy Garchow
    August 12, 2009 at 9:41 pm
    There is no way you can properly judge gamma by that picture, and definitely not through Quicktime on your computer monitor.
    Jeremy
  • Gary Adcock
    August 13, 2009 at 10:44 am
    [Jeremy Garchow] “There is no way you can properly judge gamma by that picture, and definitely not through Quicktime on your computer monitor. “
    I agree JG.
    Navarro note that you will need to also trash your QT prefs after installing FCS3 to access the new gamma rendering intent feature for the previous versions, The original ProRes versions will retain the previous gamma settings until the prefs are purged.
    See the new PR versions have the gamma settings correct on install, the existing PR versions will need to have the prefs re-set to allow the new gamma settings to stick.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflow for the Digitally Inclined
    Chicago, IL
  • Navarro Parker
    August 13, 2009 at 4:32 pm
    Thanks for the heads up. I’m assuming the file is user/library/preferences/Quicktime Preferences?
    I rendered all those with ProRes’s auto gamma on.
