Activity Forums Apple Final Cut Pro Legacy Gamma info not available
  • Gamma info not available
    Posted by Dustin Ward on August 25, 2011 at 10:35 pm
    So I realize that I can go to the format of a clip and change the gamma within the item properties, I do it all the time, but this time it says nothing next to Gamma and I can’t insert a value. Do you know why? I exported the footage as ProRes 422 from After Effects and imported it into Final Cut Pro, so I was hoping to switch the color space back to adobe so that it looks the same as I colored it in After Effects.
    Jeremy Garchow replied 15 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 25, 2011 at 10:46 pm
    First of all, you should set AE to use rec709 so that AE will match the footage, not the other way around.
    Second, you can only change gamma of RGB images.
