Activity › Forums › Blackmagic Design › gamma / color shift with blackmagic uncompressed codec
  • gamma / color shift with blackmagic uncompressed codec
    Posted by Torsten Lohrmann on May 10, 2008 at 2:33 pm
    hi @ll
    great forum!
    we have a problem with the blackmagic codec [wich we need to use, because we have decklink cards to preview our jobs on class 1 monitors]
    making a composition with a color solid and rendering this comp results in different colors depending on the output-module settings:
    rendering a 1024×576 PAL composition in 4 different ways:
    1. 1024×576 animation codec
    2. 720×576 animation codec
    3. 1024×576 blackmagic uncompressed 10 bit codec
    4. 720×576 blackmagic uncompressed 10 bit codec
    if we compare the rendered results in final cut pro they are pretty similar to each other, except of the BM-coded 1024 clip, its much lighter and also the color-channels have changed more than a little…
    any ideas?
    TIA
    torsten
    Torsten Lohrmann replied 18 years, 4 months ago 2 Members · 2 Replies
  • Margus Voll
    May 12, 2008 at 4:10 pm
    Hi.
    I bet one is rgb colorspace and the other one is yuv.
    Margus
    https://iconstudios.eu
  • Torsten Lohrmann
    May 12, 2008 at 4:43 pm
    i will check it tomorrow and let you know…
    i hope that you are right, that would solve a lot of problems…
