Activity Forums Apple Final Cut Pro Legacy Gain Filter causing sync issues
  • Gain Filter causing sync issues
    Posted by Michael Orlansky on June 11, 2010 at 5:44 pm
    Anyone ever experience an audio filter (gain filter in this case) throwing the sequence out of sync? With the filter on the sequence was out of sync, with the filter off the sync was fine.
    After toggling it on and off several times it finally did the right thing. Any ideas what could cause this issue? (We’ve seen it twice now in two different projects, same gain filter.)
    Mike
    Michael Orlansky replied 16 years, 2 months ago 2 Members · 3 Replies
  • David Roth weiss
    June 11, 2010 at 5:51 pm
    What type of footage are you cutting? A long GOP format perhaps?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Michael Orlansky
    June 11, 2010 at 5:54 pm
    DVCPRO50, captured directly from Digibeta tapes.
    Mike
  • Michael Orlansky
    June 11, 2010 at 8:39 pm
    Just had the issue again. This time instead of the audio going out of sync it simply dropped about 4 seconds of audio then started it in sync.
    Mike
