Activity Forums Apple Final Cut Pro Legacy G5/FCP Storage
  • Posted by Mike Golding on March 31, 2009 at 12:40 pm
    up until now, I have just edited and used the 2nd Sata drive as my storage area. I am undertaking a bigger project now and have a question on the storage requirements for this. I am using a G5 with FCS 2 installed. Working in SD via IO LA/LD for capture. Do I need to connect an external raid on this or can I still use the internal drive when working with 8/10 bit uncompressed. If I do need to go to an external raid, is there an easy way to do this? Thanks in advance
    MBP 2.4 4GB Ram/FCS2
    Power Mac Dual 1.8 G5/5.5GB Ram/Radeon 9600/FCS2
    Aja io hd for MBP/ Aja io LA&LD for G5
    Mike Golding replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
