Activity › Forums › Apple Final Cut Pro Legacy › G5 power on doesn’t always “catch”
  • G5 power on doesn’t always “catch”
    Posted by Nick Ryan on December 15, 2005 at 3:02 pm
    I turn on my power supplies, I turn on the Medea, and then I come around the workstation and push the power button on the front of the G5. Sometimes it turns on immediately and powers up (with chimes), sometimes the little light comes on and then goes right back off (no chimes). If it doesn’t “catch” the first time it usually will on the 2nd (and occasionally the 3rd) time.
    No real problem, just curiousity. Is this normal?
    Nick
    Nick Ryan replied 20 years, 9 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    December 15, 2005 at 4:43 pm
    MIne always starts the first time, but sometimes there’s no chime.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jeremy Garchow
    December 15, 2005 at 5:58 pm
    First, the obvious. Are you pressing the button for too long or too short? DO the fans spin when the button goes on and off? Do your APCs have a “warm up” time? It sounds like maybe they aren’t completely powered up when you try and turn on the G5. If you totally unplug a G5 from the wall and try and turn it on, the little light will still come one in the front for a bit and then go off. There’s some power stored in the power supply somewhere even though it’s not receiving power from the wall.
    When you say power supplies, you mean some sort of battery backup APC, and how old is your G5? I found that this will drain the little internal clock battery (also called a PRAM battery) faster than when the unit is plugged into to constant power (with the G5 turned off). You might want to try replacing that battery. I forget the size of it, but it’s something like a 3.6v lithium. OPen your G5 and you should see a little half size battery attached to the mother/logic board. You can pull it out and check the requirements/size. Any Radio Shack should have it.
    Jeremy
  • Nick Ryan
    December 15, 2005 at 6:54 pm
    Ah, ok… this is interesting. I’ll bet it has to do with the warm up time, as you say. Yes, they’re battery-backup APCs.
    Nick
