Activity Forums Blackmagic Design G4 & HD w/decklinkSP
  • G4 & HD w/decklinkSP
    Posted by Matt Short on February 27, 2006 at 7:26 pm
    I have a G4 dual 1.42 w/2gb ram. This qualifies to handle uncompressed HD according to FCP specs on Apple’s website. If I get a SATA raid with uncompressed HD material already loaded can I downconvert my edit to BetaSP using the decklinkSP card? Also, can I monitor the HD edit through the SP card?
    Kristian Lam replied 20 years, 6 months ago 2 Members · 3 Replies
  • Kristian Lam
    February 28, 2006 at 5:10 am
    Hi Matt,
    There are a couple of reasons why this is not possible.
    1) We’ve received numerous reports of poor performance using SATA cards in G4s. The 33MHz PCI slot on the G4 will not be fast enough to provide decent performance for the playback of uncompressed HD.
    2) When you add a DeckLink card, you place an even heavier load on the shared PCI bus in the G4. You’ll simply run out of bandwidth to do any uncompressed HD work. This is why the G5 and the new PCIe G5s are much better for uncompressed HD work.
    3) Playing uncompressed HD and doing down conversion is a fairly hefty job. The G4 does not have the grunt to do this.
    regards
    Kristian Lam
    Blackmagic Design
  • Matt Short
    February 28, 2006 at 1:52 pm
    Thanks Kristian. I guess I’ll just have to suck it up and get a G5.
  • Kristian Lam
    March 2, 2006 at 5:32 am
    Hi Matt,
    Do make sure that the G5 has PCI-X slots.
    regards
    Kristian Lam
    Blackmagic Design
