Activity Forums Storage & Archiving G Technology Raid Not Mounting
  • G Technology Raid Not Mounting
    Posted by Jonathan Tortora on May 22, 2010 at 4:28 pm
    I have a G-Tech Raid Mini and a G-Tech 2TB Raid. I am trying to mount my G-Raid first and then the Raid mini by connecting it to the G-Raid. For some reason it will only mount when it’s first in the chain. Since this drive is portable, I’d like to be able to disconnect it without interrupting the entire external HD chain.
    Any suggestions/thoughts?
    Charles Taylor replied 16 years, 3 months ago 3 Members · 3 Replies
  • Dave Klee
    May 24, 2010 at 7:58 pm
    Hey Jonathan, what connectors are you using to hook everything up? All Firewire 800? Do you have the power switch turned on with the G-RAID when it’s first in the chain?
    Pretty sure that your G-RAID would need to be turned on in order to pass the firewire connection through to the Mini. Just want to make sure that’s the way you tried it.
  • Jonathan Tortora
    May 24, 2010 at 8:15 pm
    Hi Dave, thanks for the message. Everything is connected via firewire 800 and the drive is powered on. Still no dice.
  • Charles Taylor
    June 23, 2010 at 8:22 am
    Probably far too late on this one, but did you try swapping the ports on the pass-through drive?
    Director of Photography
    http://www.CharlesAngusTaylor.com
