Activity › Forums › Storage & Archiving › G-Speed Q failure – possible workaround?
  • G-Speed Q failure – possible workaround?
    Posted by Todd Fletcher on November 4, 2013 at 3:19 pm
    So I have several G-Speed Q’s and one stopped working this weekend. The red light flashes when I start it out and it won’t mount. However all the modules are still blue lights.
    I was wondering. If I up all the modules in my other G-Speed Q (maintaining same position of each drive) should I theoretically be able to access those drive again?
    I plan to ask G-Speed tech support but we are an our before their support lines are open.
    Thanks in advance!!
    Rainer Wirth replied 12 years, 10 months ago 2 Members · 3 Replies
  • Rainer Wirth
    November 5, 2013 at 6:06 pm
    Yes, if it`s exactly the same G-speed it should work. By the way, if it works, you know that it is not the drives, but some other piece of G-tech hardware. My guess is: it`s the controller. If it is the controller you can throw it away, or you persuade G-tech to get a replacement.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Todd Fletcher
    November 5, 2013 at 6:31 pm
    UPDATE: I ran Disk Warrior on it, and it rebuilt the tables – now it works great. Much better outcome then I was fearing.
    Thanks for the reply!
  • Rainer Wirth
    November 5, 2013 at 11:08 pm
    Great,
    good luck
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
