Activity Forums Storage & Archiving G-RAID thunderbolt 3 connected to thunderbolt 2 iMac
  • G-RAID thunderbolt 3 connected to thunderbolt 2 iMac
    Posted by Varun Trikha on August 9, 2019 at 5:55 am
    Hello,
    How can I use G-Tech G-RAID Thunderbolt 3 with my 2014 iMac with thunderbolt 2 ports? I can’t find a thunderbolt 2 to 3 adapter but I have come across thunderbolt 3 to 2 adapter from Apple.
    So, is it possible that I could connect a thunderbolt 3 to 2 adapter to the G-RAID drive and connect a thunderbolt 2 wire (thunderbolt 2 on both ends) to my iMac and to the adapter. Will that work fine and give me thunderbolt 3 speed?
    Or should I just use a G-RAID Thunderbolt 2 drive with my iMac?
    Thank you.
    Varun Trikha replied 7 years, 1 month ago 3 Members · 3 Replies
  • Neil Sadwelkar
    August 12, 2019 at 11:32 am
    The Apple Thunderbolt 3 to 2 adapter works in both directions.
    So, using that, you can connect a Thunderbolt 2 Mac to a Thunderbolt 3 drive.
    Or, you can connect a newer Thunderbolt 3 Mac to an older Thunderbolt 2 drive.
    Both work with the Apple Thunderbolt 3 to 2 adapter.
    Other brands may not work, but the Apple one works for sure.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Rainer Wirth
    August 13, 2019 at 2:39 pm
    Hi folks,
    the adapter works, but the speed is Thunderbolt2 provided with your imac
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Varun Trikha
    August 14, 2019 at 7:50 am
    Thank you very much. This information is highly useful,
    I made a huge mistake though. After several unsuccessful attempts in contacting G-Tech and after having talked to the Apple customer care number a couple of times, I still had not found a certain answer to my query. With the work pressure building up, I hastily placed an order for the thunderbolt 2 drive on amazon. I wish I had waited a bit more. Since I have unpacked the drive, I dont think it is possible to return it or exchange it with the thunderbolt 3 drive and pay the surplus. But I guess it’s life and hopefully I have learnt my lesson.
    Thanks again for your help.
