Activity Forums Apple Final Cut Pro Legacy G-Raid mini problem/question
  • G-Raid mini problem/question
    Posted by Chuckfaz on February 14, 2007 at 4:07 am
    Is the G-Raid mini striped right out of the box or do I have to ‘raid’ it myself?
    Does it need to be powered or can I use it being powered via the firewire cable?
    I ask because my new $500 160 gig drive just won’t play video this evening
    TIA
    Best,
    Chuck
    Charles Fazio
    Managing Partner
    Mark Rivera’s NewYork State of Mind Entertainment Group (NYSOM-EG)
    Entertainment
    Don Greening replied 19 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    February 14, 2007 at 4:31 am
    [chuckfaz] “Is the G-Raid mini striped right out of the box or do I have to ‘raid’ it myself?”
    There are two hard drives in this unit that are raided via hardware, so they will show up as only one drive. But, it would be wise to erase it and format it MacOS extended…just in case. I do that with every new drive.
    [chuckfaz] “Does it need to be powered or can I use it being powered via the firewire cable?”
    The G-Raid Mini is bus powered. But if it is the regular G-Raid, you need power.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Don Greening
    February 14, 2007 at 5:31 am
    [Shane Ross] “The G-Raid Mini is bus powered. But if it is the regular G-Raid, you need power.”
    Just to add to Shane’s comment: Your G-Raid mini also has a power adapter and since the owner’s manual states that you may need to augment the FW (power) connection with some computers I’d suggest trying the power adapter if you’re having problems keeping the mini powered on with only the FW connection. If you’ve got something plugged into the other FW port at the same time there might not be enough left for the mini. Just a thought.
    FWIW I use the mini with a 17″ Macbook Pro and don’t need to use the power adapter. Works fine for me.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • Don Greening
    February 14, 2007 at 5:38 am
    I noticed your post in the Canon forum and was wanting to help but I don’t know squat about the H1. Just curious to know if you found a solution and were able to capture OK (Is this known as thread jacking?) :0
    – Don
  • Shane Ross
    February 14, 2007 at 5:45 am
    This is. There is a thread in this forum about it…
    https://forums.creativecow.net/readpost/8/923790?pview=t#head
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Don Greening
    February 14, 2007 at 6:06 am
    So noted. And thanks for the link.
    – Don
