Activity Forums Apple Final Cut Pro Legacy G-RAID Crashing
  • G-RAID Crashing
    Posted by Ted Ryan on August 17, 2010 at 12:58 am
    Hi Guys,
    Today I decided to back up my feature length movie, which I’m about 60% through.
    The movie is about 1.2 TB and exists on a 2TB G-RAID.
    I am editing on a MAC DESKTOP.
    And I planned on copying the project onto a 4TB G-RAID – which I just bought.
    Unfortunately, the MAC only has (1) Firewire 800 Drive – which the 2TB is plugged into.
    So I decided to “piggyback” the 4TB into the 2TB – by basically plugging the FireWire 800 Cable from the back of the 4TB into the 2TB.
    This was not a bright idea.
    The second I did it, I got a quick error message about the Scratch Discs for my Final Cut Project being messed up.
    Then when I opened my Final Cut Project and I believe I was told
    Cannot change the project because the Settings for the scratch disc is not set to Read/Write for the following path –
    VOLUMES/GRAID/MY FEATURE PROJECT/FINAL CUT DOCUMENTS.
    I opened the project, getting a little nervous.
    I could work on it but when I tried to save it, I got –
    FILE ERROR – The specified file is locked.
    So I did some research and found I needed to change my security settings.
    Easy enough I thought. I’ll just make sure Final Cut Documents is set to Read & Write and I should be on my way.
    But, when I tried to change the security settings of FINAL CUT DOCUMENTS on the Get Info tab, I could not change the preference to READ & WRITE. I could unlock the icon but the other options remained gray.
    So I called my buddy.
    He had me to attempt to REPAIR THE DRIVE.
    But, when I ran that process, there was a message about a node/structure error.
    And, that’s when said – it could not be repaired and it also says I cannot save any of the files on the GRAID. I also get a warning to backup all my files.
    So – long and the short – I believe my 2TB GRAID with my entire movie is about to crash.
    I have all the tapes and I can re-digitize and resync all the audio so I’m not as f-ed as I could be.
    If anyone has any advice or how to save this – please do.
    When I tried transferring the files (by not piggybacking), I got a message some of the files could not be copied over because they are READ ONLY.
    Ted
    Jeremy Garchow replied 16 years ago 2 Members · 1 Reply
