Activity › Forums › Apple Final Cut Pro Legacy › G-DRIVE MINI setup on MBP
Posted by Valerie Vozza on January 2, 2010 at 4:55 pmOK, just hooked up my G DRIVE MINI via FW800 to MBP 2.8.
Z7U is hooked up to G DRIVE for capture. FCP will not see both devices at the same time. When I turn camera on, G goes offline with warning.
What am I doing wrong? I’ve never edited on laptop before, only my towers. ThanksDavid Roth weiss replied 16 years, 8 months ago 3 Members · 5 Replies -
David Roth weiss
January 2, 2010 at 5:29 pmIf all else failsoutou might be forced to capture to your internal system drive, then move the files to the external drive for editing.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Valerie Vozza
January 2, 2010 at 6:08 pmThanks David, but you didn’t answer my concern.
Can I daisy-chain 2 devices on a MBP via the 800 port? -
Zane Barker
January 2, 2010 at 6:32 pm[Valerie Vozza] “Can I daisy-chain 2 devices on a MBP via the 800 port?”
Sometimes you gan get away with it but for video capture I would never recommend it.
If your MBP has an express slot look into getting a esata card that you can use to connect to esata drives with (esata is 2x as fast as FW800) Or you would get a FW card that plugs into the express slot thus giving you a completely separate firewire bus.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Valerie Vozza
January 2, 2010 at 6:44 pmno express card slot.
really frustrated with Apple support
what about a FW hub? -
David Roth weiss
January 2, 2010 at 7:52 pm[Valerie Vozza] “what about a FW hub?”
A firewire hub does nothing different than daisy chaining, you’ve got one firewire bus on your computer, period, end of story. You can increase the number of ports in and out of that firewire bus all day long, but in the end all data flows through that one bus, which is a bottleneck. This is why I told you that if all else fails you must capture the internal hard drive then move the data to your external drive for editing.
There isn’t an editor on the planet who’s happy with what Apple did to their newest laptops, but honestly, that information has been out there for many months now, and it’s common knowledge that the 17″ model is really the only one suitable for professional editing, as it still has an Express slot.
David Roth Weiss
