Activity › Forums › Apple Final Cut Pro Legacy › FYI, SuperDuper did the trick!
  • FYI, SuperDuper did the trick!
    Posted by Rich Rubasch on January 26, 2006 at 8:36 pm
    I found SuperDuper to be a better drive cloner than Carbon Copy Cloner. Better standard Mac interface, better help, better support..worked perfectly in Tiger on a G5.
    Rich Rubasch
    Tilt Media
    Chris Poisson replied 20 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
  • Bryce Whiteside
    January 26, 2006 at 8:49 pm
    Thanks for the feedback! It’s great when an orginal poster reports a successful resolution of their issue.
    Thanks again,
    Bryce Whiteside
  • Kevin Monahan
    January 26, 2006 at 9:33 pm
    Why not just use Disk Utility? It performs the same function.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Mitchji
    January 26, 2006 at 9:57 pm
    [Kevin Monahan] “Why not just use Disk Utility? It performs the same function.”
    Hi Kevin,
    I have found that DU does a slightly better job because with Superduper there will be a few minor problems reported with Diskwarrior. Here is what the developer said:
    “We’re using Apple utilities, at the lowest level, to do the actual disk erase and file copy, and those utilities are causing the ‘errors’ Disk Warrior is reporting. None of these errors are of any significance, so I truly wouldn’t worry about them: they’ll do no harm.
    I know that sounds like ‘passing the buck’, but there really is nothing we can do to prevent the problems: we’ve reported the issue to Apple, and they might be fixed in future OS releases. In the meantime — do not be concerned. Disk Warrior is just being overly ‘sensitive’ in indicating extremely minor things as error (minor things that would be found even in a brand new Mac).”
    On the other hand right now if I use DU on my main boot partition it crashes, the partition becomes unbootable and I need to run DW to get it back (not acceptable).
    Best Wishes,
    Mitch
  • Dan Riley
    January 26, 2006 at 10:23 pm
    One of the nice things about SuperDuper! is the scheduling of scripts.
    Overnight SuperDuper! looks at my media drive RAID and copies over
    to one of my Firewire 800 backup drives, whatever has been added or changed
    while editing that day. I set it to look into a folder I call “FCP Media”
    on my SATA RAID. In there are the audio render, auto save, capture
    scratch, etc. files. I then set SuperDuper to look at only the folders within
    those folders that have to do with a particular project I’m currently working on.
    This means I can backup an entire project to one firewire 500 gig drive and
    keep it as a separate backup for each project, from the entire 2 TB RAID.
    Generally my shows take up about 450 gigs for all offline, uprez,
    graphics and audio. So this works out quite nicely for me.
    Dan
  • Chris Poisson
    January 27, 2006 at 2:30 pm
    Personal Backup does the same things. FYI
    Have a wonderful day.
  • Dan Riley
    January 27, 2006 at 5:41 pm
    What’s “Personal Backup”?
    Dab
  • Dan Riley
    January 27, 2006 at 5:46 pm
    Did the google and found Personal Backup. Never heard of it previously.
    OK, at three times the price is it three times better than SuperDuper! ?
    I don’t see any glowing reviews.
    Dan
  • Chris Poisson
    January 29, 2006 at 10:04 pm
    Sorry Dan, I don’t know anything about Super Duper, but PB is very good.
