Activity Forums Apple Final Cut Pro Legacy FYI Strange ‘General Error’ Solution
  • FYI Strange ‘General Error’ Solution
    Posted by Alex Elkins on October 19, 2010 at 2:22 pm
    Hi All,
    I just wanted to share a strange solution I found to a General Error warning I’ve been getting. This isn’t something that will fix every General Error, obviously, but might help with future troubleshooting…
    The Scenario:
    FCP 7.0.3
    Sequence containing a nested sequence.
    In/Out points set
    Exporting using QuickTime conversion to h.264
    As soon as I OK’d the export I would be hit with the General Error error. Exporting worked on other sequences, so clearly the problem lay in this one sequence. I trashed render files and tried again to no avail. Didn’t get as far as trashing preferences because I discovered…
    The Solution:
    Turned out that by accident the in point of my sequence was set 1 frame after the frame the nested sequence began at. As soon as I shifted the in point back 1 frame it worked without any issues.
    The Conclusion:
    Well, there really isn’t a conclusion because exporting should work wherever the in point is set. But there you go, that was what fixed it so maybe this information will help people in the future.
    Salad Daze Films – Freshly Tossed
    Check out my latest addition to the Creative Cow Reels Section
    Alex Elkins replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
