Activity › Forums › ARRI › FYI: – LogC to LogC DPX support added.
  • FYI: – LogC to LogC DPX support added.
    Posted by Robert Monaghan on January 19, 2011 at 2:51 pm
    Hi Guys,
    This is something of a cross post.
    I have added the ability to export LogC ProRes (or LogC ARRIRAW) to DPX using my CineonDPX package.
    (Download v3.5 build 2299)
    The setting is called “LogC MOV to LogC DPX”. You can find it in the System Preferences->CineonDPX pane. Click on the “DPX Export” tab and change the “Conversion” popup menu to “LogC to LogC DPX”. You can then use any QuickTime enabled tool to easily export a LogC ProRes files to a set of LogC DPX files.
    The DPX Compressor encoder has also been updated, to export from a LogC Source.
    Also, I wanted to add that I have added renderless LogC -> Rec709 Support, using ARRI’s Color Science, for Final Cut Pro. Take a look at the ARRIRAW Toolkit package.
    bob..
    Robert Monaghan, CEO
    Glue Tools LLC
    POBox 24124
    Santa Barbara, CA, 93121
    United States
    tel: +1 805 456 7997
    fax: +1 805 456 7998
    http://www.gluetools.com
    Robert Monaghan replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
