Activity › Forums › Blackmagic Design › FYI: How to edit HDV in Ppro 2.0 using DL SD card
  • FYI: How to edit HDV in Ppro 2.0 using DL SD card
    Posted by Baz Leffler on February 17, 2006 at 5:55 am
    Confused with the subject? OK… I recently had to do an urgent HDV edit shot with some Sony Z1 HDV camera’s. The only free computer available was a ‘Decklink Extreme’ SD. I opened up a new PPro 2.0 project and selected ‘Adobe HDV > HDV 1080i 25 (Sony 50i)’ as I am in PAL land.
    I then used my Sony HVR-M10P deck and captured all the required tapes via the firewire control as native HDV mpeg files. OK… all is normal so far… but now a great trick!…
    I then went to playback settings and set ‘external device’ to “monitor 3” as I had the Decklink card set as an extension to my desktop… and voila!… the output HDV image was realtme converted to SD and displayed on my grade 1 component video monitor AND output thru the SDI (albiet in letterbox 4:3 but if the Decklink could tell the desktop that it is a 16:9 monitor then Premiere might display it as 16:9FHA).
    And for those who go “but I wanna preview in HD but not use my second vga monitor”… I can also view it on my HD monitor using the component out of the HDV deck via firewire but I haven’t had a chance to hook that up.
    Manololp replied 20 years, 7 months ago 3 Members · 2 Replies
  • Shane Chadder
    February 18, 2006 at 7:16 pm
    If you try and do the same thing with an HDPro card there are some conflicts that show up when you use the source viewer…so they are almost there.
  • Manololp
    February 20, 2006 at 12:50 am
    Hello. Ok, it does work. Thanks for the info.
