Activity › Forums › AJA Video Systems › FYI: Combustion 720×480 framebuffer – still broken in 6.0.2
  • FYI: Combustion 720×480 framebuffer – still broken in 6.0.2
    Posted by Alan Okey on January 6, 2009 at 4:27 am
    This is an update to the original thread found here:
    https://forums.creativecow.net/thread/98/871887
    The issue has not been resolved in the latest release of the Kona drivers (6.0.2). Oddly enough, there are specific “DV” framebuffer settings listed for PAL resolutions, but not for NTSC.
    PAL settings include:
    AJA Kona 625i25 10 Bit
    AJA Kona 625i25 8 Bit
    AJA Kona 625i25-DV 10 Bit
    AJA Kona 625i25-DV 8 Bit
    But the NTSC settings do not include the “DV” versions:
    AJA Kona 525i29.97 10 Bit
    AJA Kona 525i29.97 8 Bit
    The “DV” suffix in the framebuffer listings denotes a field shift correction for interlaced 720×480 comps, which require video output to be shifted up or down by one field in order to preserve proper field order on playback.
    A fix for this issue was promised back in November for the 6.0.2 release, but apparently it didn’t make it in.
    Alan Okey replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
