Activity › Forums › AJA Video Systems › FYI, Apple Info doc on Io’s and Soundtrack audio out
  • Tony! Hulette
    April 6, 2006 at 8:33 pm
    Good to know. Thanks for the update AJA.
    Tony!
    Soundtrack Pro: How to use AJA Io to monitor audio
    You can use the AJA Io, an external output device, to monitor audio with Soundtrack Pro. However, setting up the Io is different that setting up a typical Core Audio interface. Here’s how to do it:
    Import a video into a Soundtrack Pro project to monitor audio through the AJA Io.
    Open the Soundtrack Pro preferences (Soundtrack Pro > Preferences).
    Click the Video Out button.
    Select the appropriate AJA output option from the Video Out pop-up menu.
    Make sure video out is enabled. You can toggle Video Output on and off by pressing Command-F12. (Soundtrack Pro playback must be stopped while toggling the setting).
  • Lee Berger
    April 7, 2006 at 12:12 pm
    This only addresses part of the problem. You still cannot use the Io to record in Soundtrack Pro and you can only use the Io for playback if there is a video file imported. I would like to use soundtrack and Io for all of my audio recording and monitoring in Soundtrack.
