Activity Forums Apple Final Cut Pro Legacy FXScript Error : Syntax error
  • FXScript Error : Syntax error
    Posted by Michelle De long on November 14, 2005 at 8:19 pm
    I am rendering out some effects on a timeline including a green screen Matte shot as well as some gaussian blurs and brightness/contrast filters on a series of clips.
    When I go to render them out about halfway through the render an error pops up that says :
    “FXScript Error : Syntax error” and certain clips are un rendered. I have quit out and rendered twice and the same clips have been unrendered each time.
    Does anyone know how to get around this or why it is happening?
    Mohammad Dardir replied 17 years, 7 months ago 3 Members · 4 Replies
  • Kurt Hennrich
    November 15, 2005 at 1:29 am
    it seems that you have faced a bug in one of the plugins you are using
    which might be beyond your skills to repair.
    try to deactivate one of the plugins to see if the clip does finish rendering without error.
    when you have found the plugin makeing troubles
    hopefully you will find another soulution to get what you want.
    and please report back the name of the beast.
    good luck,
    kurt
    Kurt Hennrich
    1z1screenworks
    1z1 tools for FCP : https://www.1z1.at/plugins/
  • Michelle De long
    November 15, 2005 at 4:46 pm
    Well the strange thing is that the only effects being used are not plugins but effects that come with Final Cut, specifically the blue and green screen matte combined with a desaturate and brightness/contrast filter. All of these are somewhat standard procedure filters except for the green screen which is somewhat complicated but nonetheless ought to work.
    The other possible culprit might be my clients external drive. It is loud and clunky and old looking and a brand that i’ve never heard of: “Ultra.” So I don’t know.
  • Kurt Hennrich
    November 15, 2005 at 5:12 pm
    [Michelle De Long] “Well the strange thing is that the only effects being used are not plugins but effects that come with Final Cut”
    nearly all original FCP effects you find under menu ‘video filter’ are plugins, but they are stored inside FCP
    concerning harddisk: I would stop working with immediately and try to make a 1:1 copy of it to a new disk.
    quit FCP – copy whole disk to new one – give new disk same name as old one – disconnect old disk – restart FCP.
    good luck,
    kurt
    Kurt Hennrich
    1z1screenworks
  • Mohammad Dardir
    February 3, 2009 at 10:08 am
    I am rendering out some clips on a timeline indicating a green par.
