Activity › Forums › Apple Final Cut Pro › FXFactory crashing FCP 10.0.3
Posted by Andy Field on January 31, 2012 at 4:12 pmBeware – FXFactory (latest downloaded version) keeps crashing 10.0.3
Patrick Monaghan replied 14 years, 1 month ago 3 Members · 3 Replies -
Andy Field
January 31, 2012 at 8:07 pmhave to say FX Factory Tech support is outstanding – they found issues in Quartz Composer Patches folder — if anyone has the same issue – here’s the fix they sent me –
FROM FX Factory support
I recommend that you navigate to the following directory on your system:
/Library/Graphics/Quartz Composer Patches
– AlphaBlendMode.plugin
– AudioTools.plugin
– FileTools.plugin
– GLTools.plugin
– GLTools_NoAlphaBlend.plugin
– StructureTools.pluginI would remove all components except the “GLTools” component (of which you have a duplicate).
The “AlphaBlendMode 1.0” component is particularly bad. It likely ended up on your system when you installed Boris plug-ins (although it is *not* made by Boris). I recommend that you replace it with a newer version:
https://kineme.net/release/AlphaBlendMode/11
Andy Field
FieldVision Productions
N. Bethesda, Maryland 20852 -
Patrick Monaghan
August 10, 2012 at 5:49 pmYou may *also* be interested to know that the AlphaBlendMode.plugin *ALSO* caused the iMovie Title Browser to not key properly. It has taken many hours to sort out this problem, and if I hadn’t opened up Final Cut Pro X to check that it would key a title properly *and* seeing the warning from FX Factory, I wouldn’t have solved two problems at once.
– o –
be the actor in your life
