FX7 Adobe Premiere Pro Capturing Problems
Alright so first off….. Everything has worked in the past. My computer is fine, camera is fine, no other problems until now.
I had used a tape in a DV camera and it was still good so then I used it in a HDV camera. You can tell the difference but there aren’t any problems playback is fine etc.
So I used DV capture in premiere to capture the video of the DV section, & once it hit’s the HDV video it stops. I saved the DV video and went on to record the HDV section. Though now, it says the capture device is offline for the HDV. (I can control playback and all that good stuff through it though) The capture settings are set for HDV and everything so I didn’t get it! I then went and switched it back to DV to just see, and it reads it but I don’t see any picture!!!
BUT STILL, this is the High def section of the tape and why should I have to convert using the DV settings? I am so confused guys and am sort of rushed also! Any response or questions or whatever will help me I appreciate it!
Thanks guys!
