Activity › Forums › VEGAS Pro › FX window for several events visible
  • FX window for several events visible
    Posted by Stewart Bourke on May 3, 2010 at 9:26 pm
    Anybody know if there is a setting to allow the event-fx window for multiple events be open at the same time?
    I have two events from the same show, shot over two nights, and the lighting was very different on the two nights. I am using keyframes on various effects (colour correction, brightness etc) to transition between the events (there is a stage-lighting red-blue transition as well which I am using to ‘hide’ my transitions), and it would be very useful if I could see the fx event windows open for the two events at the same time.
    When I open the fx window, it always seems to replace the current one, and I cannot see anything in the options which gives me this option. Since the windows are not modal, I thought you might have been able to have multiple fx windows open at the same time..
    Stewart Bourke
    John Rofrano replied 16 years, 5 months ago 2 Members · 1 Reply
  • John Rofrano
    May 3, 2010 at 11:29 pm
    There is no way to do this. I usually take a screen capture of the FX window before I open the other. You can also save presets in one and use them in the other. Then delete the preset.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
