Activity Forums Apple Final Cut Pro Legacy FX Script Error
  • FX Script Error
    Posted by Sam Lesante jr. on September 23, 2009 at 3:45 pm
    So i am trying to render my project out.
    I was able to render out a couple clips but half way through a window comes up and says “FX Script Error – Variable is Read Only”
    All the clips are read and write so i don’t know what the problem is.
    Any suggestions?
    TIA
    Sam
    Wayne Kurtz replied 13 years, 2 months ago 3 Members · 2 Replies
  • Arnie Schlissel
    September 24, 2009 at 3:09 am
    There’s a problem with one of your plugins. You’ll have to figure out which filter on which clip by turning them off one at a time until the sequence exports.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Wayne Kurtz
    July 2, 2013 at 5:09 pm
    I also have same issue. Probably one of my editors used a plug in which is not loaded onto my machine.
    It is large project and very hard to find it to remove. What if I leave it in the timeline? Will it play without a transition there or will a “not on file” or something message pop up when reachign that point?
    I sent project to compressor and there was no warning of “offline media”
