Activity Forums VEGAS Pro FX Problem in Boris
  • FX Problem in Boris
    Posted by Accountclosed on November 14, 2005 at 1:31 pm
    https://forums.creativecow.net/
    Hello i am Majnoo from Pakistan i just bought BorisFx and found its amazing can anyone from you people help me i am facing problen while applying boris FX tranlations or ETC in Vegas 6.0
    when i try to apply the FX Translation i found that Effect is Applying only on one image but not the second image you know what i mean
    I cannt apply effect / Translation on both images infact then second image is only simple but effects are working only on 1st image
    i think you people know what i mean .
    so plz help me
    Thanks in Advance
    Regards
    ALi…
    Glass Onion replied 20 years, 8 months ago 3 Members · 4 Replies
  • Edward Troxel
    November 14, 2005 at 4:39 pm
    Did you put both clips on the SAME track and simply overlap them?
    If they are on different tracks, you’ll have to apply it to both the fade out of the first event AND the fade in of the second event. Just put both clips on the same track and overlap them.
    Edward Troxel
    JETDV Scripts
  • Accountclosed
    November 15, 2005 at 5:23 am
    yes that what i am doing but its not working i am applying effects on crosfade in the middle of both tracks but can’t get rid of this prob
    thanks for replying
    Regards ALi
  • Edward Troxel
    November 15, 2005 at 2:56 pm
    What do you mean by “in the middle of both tracks”? There should be ONE track with the events overlapped on that track.
    Edward Troxel
    JETDV Scripts
  • Glass Onion
    December 28, 2005 at 5:36 am
    I have the same problem and it is killing me. Boris FX8 sucks when used with vegas 6. The transitions either start or end wrong. They look fine in the boris editor but in the vegas editor they are wrong. Does anybody use Vegas 6 with Boris Fx8 transitions successfully? Half of the boris transition don’t work correctly. The problem is the transitions eith start to early or end too soon. I wasted my money on Boris FX 8.
