Activity › Forums › Apple Final Cut Pro Legacy › FX Plugs Boost Luma Dip Chroma
Posted by John Fishbackon November 11, 2008 at 11:21 pm
I’ve just noticed that all my FxPlugins boost the in & out-going clips luma and dip the chroma during the transition. I’ve trashed prefs & repaired permissions. I have plugins from Core Melt, CHV, NI and IR. Any ideas what might be happening?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
John Fishbackreplied 17 years, 9 months ago 3 Members · 7 Replies
John Fishback
November 12, 2008 at 3:11 pmOverlays were on, but with no overlays selected. I switched overlays off and rerendered to no avail. FX Factory is v2.0.5, Polychrome v1.1, ImageFlow v2.5. This is happening to all the FxPlugs. Older FXScript transitions work fine.
John
Christoph Vonrhein
November 12, 2008 at 10:40 pmDoes this also happen when you use the internal FxPlug plugins of FCP ?
and: Does this also happen when you use Motion and use the same plugins ?
I think that there is a chance that the graphics card is damaged, as especially FxPlug plugins heavily use the graphics card to render.
Christoph Vonrhein
https://www.chv-plugins.com -
John Fishback
December 3, 2008 at 6:21 pmChristoph, I replaced the 3870 with the 2600 video card and the same luma boost/chroma dip happened.Is it more likely this is an issue with FCP & FX Factory or the OS or both?
John
Christoph Vonrhein
December 3, 2008 at 9:15 pmJohn,
I don’t think that there is something wrong with OSX. It is more likely that FCP is “messed up”.
You said that you have the problem with all FxPlug plugins from all developers. This points to a damaged FCP installation, as we now found out that it is not your 3870 graphics card. A clean FCP re-install would be my next suggestion.
Christoph
Christoph Vonrhein
John Fishback
December 3, 2008 at 9:25 pmThanks, Christoph. I’ll do a clean re-install of FCP. That’s a lot better than starting from scratch with the OS. Thanks for all your help. You’re the best.
John
John Fishback
December 14, 2008 at 8:13 pmFinal Report (I hope). I reinstalled Leopard and FCP and the issue is resolved. FXPlug transitions work as expected. I’m in the process of reinstalling all my plugins. I’m checking FCP after each install to see if a third-party program might have caused the problem.
John
