Activity Forums Apple Final Cut Pro Legacy FX Plug Corruption
  • FX Plug Corruption
    Posted by Rick Lavon on October 31, 2007 at 2:55 pm
    Hi all-
    Several of my FX plugs..(Vignette, Soft Focus) are now unusable and will not
    render. They did before, but something has become corrupted. This happens with new projects as well. Is there some sort of preference for this that is beyond the normal FCP preferences we all know and trash with regularity? It’s not just the effect with the clip. It’s the effect itself from the efx panel that does not work with any clip. I get a big red error screen.
    I obviously haved trashed the FCP pref’s already with no effect (pun intended)
    Rick Lavon replied 18 years, 10 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    October 31, 2007 at 4:30 pm
    Have you installed Leopard?
  • Rick Lavon
    October 31, 2007 at 4:45 pm
    No still on 10.4.10…but I have a feeling it is related to a 2nd video card I recently installed. I am unsure why some would work while others would not.
  • Jeremy Garchow
    October 31, 2007 at 4:56 pm
    [ral1375] “but I have a feeling it is related to a 2nd video card I recently installed”
    I would assume that as well, but I don’t have any experience adding a second graphics card. Since fxplug is tied to the graphics card, it might be getting confused.
    If you pull the second graphics card, do things stabilize? What else is in your mac for PCI cards?
  • David Bogie
    October 31, 2007 at 6:01 pm
    Thank god this has finally happened to someone else. I lost several FxPlugs many weeks ago and near zero response around here.
    https://forums.creativecow.net/readpost/8/956639
    Major Motion wonk couldn’t help me either. We reloaded and reverted a few receipts but nothing has brought these filters back form the dead. They all used to work directly from FCP, they all work fine in Motion. Not all FxPlugs are affected.
    If you want to continue the dialog, post a list which filters don’t work. I have about 8, mostly in the Blur category.
    bogiesan
  • Rick Lavon
    October 31, 2007 at 7:16 pm
    Actually, the problem is now solved. In my case it was because I had hooked up a 3rd monitor and that was interfering with the FX plugs. I unhooked the monitor, rebooted, and everything now works. I hope this is your solution too… I got this straight from Applecare
